92camrey overheating problems
Old Oct 3, 2012 | 07:28 PM
whitlatchd@gmail.com's Avatar
Default 92camrey overheating problems
i have a 92camrey 4cyl and have crazy overheating problems i have looked and found anyone else with same problem.i have bubbles in raidiator,water flowes out of overfill fast is that from pressure from a cracked head ,blowen gasget,crack in block the bubbles are really hot .i had the same problem with the orig.moter so i changed out the moter,and have the same problem are they known for having a bad moter for that year.what can i do i have tried all sealers even the blue devil with no luck on any of them . is there any hope i love that car thanks for any help.
Old Oct 3, 2012 | 09:40 PM
If you think the issue is a blown head gasket preform a block test for exhaust gases in the coolant.
Given this is the second engine with a problem have you check the cooling system, plugged radiator, etc?
Some sealants and cleaners also have effects on the radiator as in plugging it up.
Old Oct 3, 2012 | 10:06 PM
full house's Avatar
I always do this whenever I think I got blown gasket...
and it work... it sometimes blown gasket most of the time it's not.
Old Oct 4, 2012 | 04:49 AM
thanks I will have it checked is there any outher reason for the bubbles?
wayneh
Nov 25, 2016 04:09 PM
puffswami
Sep 16, 2012 12:03 PM
jeeperman
Oct 27, 2008 08:19 PM
saiman9@hotmail.com
Dec 20, 2006 07:50 PM
gruvworks
Oct 30, 2006 12:08 AM
