Noise when start, or when press gas pedal to accelerate
Old Oct 2, 2020 | 08:40 AM
workwork's Avatar
Default Noise when start, or when press gas pedal to accelerate
Hi,
My Camry recurrently make huge noise when start, or when press gas pedal to accelerate. Although there is not big noise when run without accelerate.
Do I need to replace muffler, or replace whole exhaust pipe?
Thanks in advance.
Old Oct 6, 2020 | 07:21 PM
Is this exhaust noise?
There is a flex pipe exhaust pipe that goes between the engine exhaust and exhaust mounted on the chassis. This pipe flexes to allow the engine to move and not damage the chassis piping. The flex pipe can fail. If it is this pipe take the car to a muffler shop for a replacement flex pipe. Note a Toyota dealer will only replace the complete exhaust system as mounted to chassis.
Old Oct 7, 2020 | 03:35 AM
workwork's Avatar
Thanks Mr. Toyomoho,
I can image the parts as you mentioned, just wonder, is this the correct parts?
Amazon Amazon
And, is there any flex pipe from Toyota parts:
https://parts.olathetoyota.com/searc...=&make=&model=
Thanks!
Old Oct 7, 2020 | 02:33 PM
See link below for a 2002 Camry. As you can see Toyota only offers the complete section of exhaust having the flex pipe (No 1).
https://parts.olathetoyota.com/v-200...ust-components
If buying aftermarket such as Amazon get the correct length and pipe diameter. The flex pipe design can be weld-on or bolt-on. The bolt-on flex pipe ends sliding over the original exhaust pipe tubes then held with muffler clamps.
Don't know the diameter of the exhaust pipe you have..
joser83
Jun 19, 2020 04:26 PM
Mlswords
Mar 3, 2017 10:34 PM
radone
Nov 7, 2014 09:30 AM
thedude
Aug 14, 2010 02:55 PM
dlv123
Nov 28, 2007 04:29 PM
