Radiator fans not working
Old Mar 12, 2021 | 05:48 PM
Cellex's Avatar
Default Radiator fans not working
I noticed that the two radiator fans have stopped running at all, and check engine light come on. Pls with the solution. Thanks.
Old Mar 12, 2021 | 08:14 PM
Year of car and engine type V-6 or 4-cylinder.
Check the trouble codes. Some auto parts stores will read the codes for free.
Old Mar 13, 2021 | 01:01 AM
Cellex's Avatar
Thanks for your response.
The car is Camry 2005, Engine is 4 cylinder. The engine check light is up.
Old Mar 13, 2021 | 10:18 PM
If the check light is on, there is a trouble code(s) stored in the computer. Have someone read out the code(s).
Do the fan turn on/off with the AC compressor. Turn on AC and check this.
Old Mar 14, 2021 | 04:56 AM
Cellex's Avatar
I have no one to read out the code on a computer in my area.
Meanwhile, I have done the AC check. The two fans came on and run immediately I turned the AC **** on. They never ran again after the AC was put off.
What should I do next please.
Thanks.
Old Mar 14, 2021 | 10:38 PM
Start by checking the 10A FAN RLY, 30A CDS and 30A RDI fuses The 10A fuse is located in a fuse box on the drivers side of dashboard behind the coin box/ash tray. The others are located in a fuse/relay box located in engine compartment.
2005camryleCa
Jan 4, 2020 06:21 PM
juancarloslax
Apr 23, 2015 01:01 AM
iceman187420
Jan 16, 2010 09:40 AM
camry99
Feb 6, 2009 09:59 PM
93Toyotaowner
Jan 4, 2009 04:27 PM
