SRS light won't turn off
Hey everyone,
I gave my 2003 Camry a deep clean today including fabric on/under the seats, seat belts, etc., and now for some reason the SRS light isn't functioning properly. It stays on even when seat belt is buckled. Could I have accidentally knocked some wires around and disconnected something? Where would I look to try find the SRS wires to make sure they're all connected properly?
Thanks in advance
Thanks in advance
Did you clean under both front seats? How aggressive of cleaning did you give the top of the front seats?
Does the seat belt light go out when belt is buckled?
The SRS wire harness and plug connection are under each front seat. There would be one for any seat wiring for say power seat and one for the SRS, SRS harness might be yellow in color.
The problem is even if the problem is fixed, once the SRS light goes on it doesn't go off until manually reset. This via the OBDII port.
If you know someone with an ODBII reader that can access the SRS. The reader can read the SRS code(s) and pinpoint the problem area.
Saeed Ahmed
Feb 6, 2013 01:01 PM
