Steering Wheel HELP!!!
Apr 12, 2015 | 05:44 PM
trae95
Apr 2015
My 99 Camry steering wheel makes like a whining sound when turning corners any suggestions to fix this?
Thanks!
trae95
Send a private message to trae95
Find all posts by trae95
Apr 13, 2015 | 11:18 PM
toyomoho
Jan 2008
PTW
Makes noise when you turn the wheel?
toyomoho
Find all posts by toyomoho
Apr 14, 2015 | 12:54 AM
Patonium
Nov 2013
Maine
Check your power steering fluid level, sounds like the fluid level could be low.
Patonium
Send a private message to Patonium
Find all posts by Patonium
Apr 15, 2015 | 08:41 AM
trae95
Apr 2015
Toyomoho yes and Patomium the fluid levels are good
trae95
Apr 16, 2015 | 12:48 AM
Patonium
Nov 2013
Maine
With the car in park, when you turn the wheel does it make the noise or only when the car is in motion?
Patonium
May 1, 2015 | 07:54 AM
trae95
Apr 2015
It also makes the noise with the car in park
trae95
May 1, 2015 | 09:45 AM
toyomoho
Jan 2008
PTW
If there is noise when in Park (put E-brake on).
Have someone turn the steering wheel while you listen under the hood to the power steering pump. Use a pipe or hose as stethoscope.
toyomoho
vibration at idle through the steering wheel
turboxb9s
Mar 27, 2022
04:41 AM
Steering Wheel Issue
lcc014
01:03 PM
2003 Steering Wheel Squeels
Leonard15
10:34 PM
play in the steering wheel
michael
04:36 PM
Steering wheel wobble
Dan_Lemur
02:20 AM
Flex Fuel conversion
12:47 PM
