Tail Light Problem
Old Apr 17, 2016 | 11:15 PM
Lilred's Avatar
Default Tail Light Problem
Howdy,
Posted on the DIY forum as well.
I have a 97 Toyota Camry with over 333,000 miles on it.
The tail light warning light began to come on when I brake and it stays on after I release the brake. I checked and all the bulbs are okay. What else do I need to check out?
Old Apr 18, 2016 | 10:32 AM
Suggest the following:
Replace all bulbs as sometimes a working bulb causes problems.
Check bulb sockets for corrosion resulting in poor electrical contact.
Check harness wiring for damage where harness transitions from chassis to trunk lid.
Old Apr 18, 2016 | 02:34 PM
Lilred's Avatar
thanks for replying. I did notice some discoloration on part of the plastic housing holding one of the bulbs on the right hand side. Once I break, the light comes on and stays on and later goes off as I continue down the road.
Old Apr 19, 2016 | 12:15 PM
Sensor activation is a common problem when braking. All lights can still work but the sensor light comes on after braking.
Follow the advice in the previous post and determine if the problem goes away.
On rare occasions the sensor unit itself is bad.
Old Apr 19, 2016 | 12:39 PM
Lilred's Avatar
will do. thanks
Lilred
Apr 18, 2016 10:33 AM
TMF
Jan 15, 2012 09:23 PM
Emad
Oct 13, 2011 09:28 PM
Emad
Jul 5, 2011 11:14 AM
puffswami
Aug 20, 2009 05:28 AM
