Windshield washer issue
Old May 6, 2025 | 09:40 AM
HybridSE's Avatar
Default Windshield washer issue
Hello from a newbie to the forum...
I have a 2020 Camry Hybrid SE with low mileage. I had a low washer fluid message pop up. I filled the reservoir for the 1st time since new... now I don't have fluid spraying at all. I can hear the pump working, but no luck.
Any suggestions/ ideas?
Thanks in advance.
Old May 6, 2025 | 09:49 AM
HybridSE's Avatar
Is there a trick to possibly reset the washer fluid level sensor, or does it need to be replaced?
Old May 7, 2025 | 09:21 AM
The system uses a fluid level sensor. If the fluid tank is filled and the senor is working the low fluid indicator should turn off.
When you operate the washer do you hear the sound of the fluid pump working? The pump is connected to the lower part of the tank.
Old May 7, 2025 | 10:03 AM
HybridSE's Avatar
Yes... I can hear the pump... no fluid is sprayed. The dash panel says I have low washer fluid. I did add 1 gallon and still I have zero spray onto the windshield.
Thanks for the reply.
Old May 8, 2025 | 05:50 AM
Fxstsb's Avatar
Thanks in advance.
have you ever been to the dealer?
Old May 8, 2025 | 08:57 AM
HybridSE's Avatar
Yes... they want $150.00 to diagnose the issue alone. Just asking before I pull that trigger.
Thanks for the question.
Old May 13, 2025 | 08:25 PM
The fluid level sensor can fail but can be replaced. A hose from the pump or the pump intake clog up. Youtube would have videos on accessing the reservoir which has the pump.
Old May 14, 2025 | 06:55 AM
Fxstsb's Avatar
What I would do. I would disconnect the washer hose at the reservoir and blow air through it. if air won’t go through neither will water
Old Mar 2, 2026 | 08:48 PM
nathanhenry's Avatar
I have a 2020 Camry Hybrid SE with low mileage. I had a low washer fluid message pop up. I filled the reservoir for the first time since new, and while checking around I also noticed my Can-Am Defender Light Tint Rear Windshield; now I don't have fluid spraying at all. I can hear the pump working, but no luck.
Thanks in advance.
If you can hear the pump but no fluid sprays, the likely causes are clogged nozzles, air trapped in the lines, or a disconnected/kinked hose. Check the hoses and clean the nozzles first.
workwork
Jan 10, 2026 07:30 AM
kevkev
Jan 24, 2024 06:57 AM
Cmry05
Oct 26, 2023 11:52 AM
Firefox613
Dec 5, 2022 10:31 PM
rupalimittra
Jun 7, 2021 05:55 AM
