Old Aug 26, 2015, 02:44 PM
How-Tos on this Topic
Browse all: Interior Guides
Print Wikipost
2007 4cyl Camry LE AC smell issue HELP!!
Old Oct 15, 2012 | 04:43 AM
  #11
alesha00's Avatar
This is a fantastic site and very engaging too. Excellent work! That’s not really much coming from an amateur publisher like me,
long island closing attorney
but it’s all I could think after enjoying your posts. Great grammar and vocabulary. Not like other site. You really know what you’re talking about too. So much that you made me want to explore more. Your blog has become a stepping stone for me, my friend. Thanks for the detailed journey. I really enjoyed the posts that I have read so far.
Old Jan 12, 2013 | 02:42 PM
  #12
mycarcamry's Avatar
Eww. I have the opposite problem. My Camry has an air freshener smell that I notice when I turn the fan up. I suspect the original owner put in just before selling it. I have had the car for almost two months now. Can't find an air freshener and the smell has not diminished. I actually don't mind it, it's just driving me crazy trying to figure out where it's coming from.
Old Jan 21, 2013 | 01:40 AM
  #13
BoydBooker's Avatar
I'm just curious to know how the bad fuel injectors will cause the 'noise' in the previous engines?
Old Jun 10, 2013 | 10:35 AM
  #14
1296camry01's Avatar
I'd say remove and clean out the outside vent and clean it off. You can try a steam cleaner and blow it through the vent system. You can get a cheap steamer for like $30. You could also bring it to someone for more thorough resualts. I don't know how long the resualts last but it should help. Replace your cabin air filter or check to see if it retains an Oder. Try spraying Lysol in the vent system again (I learned they from Scotty Kilmer) And stock up on air freshener. Does the valve train issue sound like a buzzing sound between 1500 and 2k rpm? My 2.2 01 does this and I'd like some info on it. Thanks hope the best!!!
Old Jun 10, 2013 | 10:45 AM
  #15
Clean your outside air vents really well. You can use a steamCleaner to clean out the vents from all angles. Try the Lysol trick again. Check and replace the cabin air filter. And stack up on air freshener. Does the valve train issue sound like a buzzing between 1500 and 2K rpm? My 2.2 01 does this. Thanks hope the best!!!
ssracing
Mar 27, 2012 12:50 AM
gabegallear
Jan 22, 2012 04:21 PM
sapper78e
Sep 8, 2011 10:12 AM
opadavis
Apr 11, 2008 08:15 PM
98camryblue
Dec 10, 2007 09:28 PM
