Sights n Sounds Post your video clips here.
Flapping under passenger front side 07 Camry
Old Apr 18, 2023 | 07:29 PM
BraydenWaggoner's Avatar
Default Flapping under passenger front side 07 Camry
Hi, I have a plastic sounding flapping noise under the passenger front side of my 07 Camry that mainly happens at higher speeds or higher wind. Very sporadic and loud. All plastic shields have been secured under engine and wheel wells. Couple mechanics have had it in the air and looked at everything and it’s all secure. Any more ideas on what this could be? Anything helps, thanks!
Old Apr 18, 2023 | 10:58 PM
Are you sure of the location?
How about engine RPM as in high RPM but lower speeds?
Old Apr 19, 2023 | 05:51 AM
I’m pretty sure about the location, could be more center maybe. RPM doesn’t make a difference, just speed.
Old Apr 20, 2023 | 08:36 AM
Possible to post audio of noise if its that loud?
Did mechanics check for mechanical issues such as wheel bearing, something loose such as disk brake shield, etc?
In case its an axle, try making 360 turns at low speeds to check for noise.
Williambertram@yahoo.com
Jan 26, 2022 03:49 PM
slammin86
Mar 3, 2010 05:41 PM
StoreKeeper
Dec 25, 2009 07:45 AM
cynglgi
Sep 22, 2007 12:38 AM
HeavyASaBoat
Jan 20, 2007 11:28 PM
