2006 toyota camry brakes
Old Aug 18, 2012 | 09:07 AM
Stephanie Ward Staton's Avatar
Default 2006 toyota camry brakes
i have a 2006 toyota camry i have changed brakes on front and bk,bleed the brakes,and adjusted them and still the peddle goes to the floor..wondering if anybody would know whats going on..
Old Aug 18, 2012 | 10:34 AM
Were the repairs an attempt to fix the peddle going to the floor?
Old Aug 18, 2012 | 11:05 AM
yes it was....
Old Aug 18, 2012 | 12:23 PM
If the fluid in the master cylinder reservoir became low enough to allow air into the system at this location the master cylinder needs to be bench bleed. Basically this is removing the brake lines from the cylinder then bleeding much like as with brake cylinder. Plug the holes with fingers when the pedal is released. Do this 3 - 4 times to remove air.
Then bleed brake cylinders stating with the brake furthest from the master cylinder.
If the car has VSC and still has problems after bleeding Toyota connects their electronic tester to activate the system for bleeding.
The master cylinder can also fail resulting the pedal going to the floor. Assuming no leaks in the brake system, etc.
stomper
10
Mar 19, 2026 10:54 PM
pluto12345
Nov 29, 2012 07:10 PM
cnyreject
Sep 12, 2011 07:23 AM
bingroy
Apr 24, 2008 07:10 PM
vamb
Sep 18, 2006 03:08 AM
