Brake pads replacement
Old Oct 16, 2021 | 07:55 AM
CamryNerd's Avatar
Default Brake pads replacement
During my maintenance check at my local Toyota dealership yesterday, I was informed that I needed new brake pads. This is believable since the car has 59045 miles on it, and I think these are the original pads. According to the chart they gave me, the following is my brake lining: Left Front (1 mm); Right Front (1 mm); Left Rear (3 mm); Right Rear (4 mm).
The dealership would charge me $552.94 to replace the front pads and roters with OEM. And they would charge me an additional $532.94 to replace "Shoes or Pads, Rotors or Drums" in the rear.
My question: Where do you go to replace break pads? The dealership or somewhere else? Would love to know what options I have that are decent.
Old Jan 11, 2022 | 10:46 AM
Shel_B's Avatar
I've been using a local wheel, brake, suspension shop for many years. Maybe there's a shop like that in your area. Even a good, more generalized shop can do brakes.
You may not need new rotors. For such low mileage and no signs of problems, like grinding sounds, vibration when applying the brakes, it's most likely your rotors are fine, maybe just need resurfacing.
Old Mar 16, 2022 | 12:06 PM
partsguy01's Avatar
Brake installation certainly isn't 'rocket science', but it still requires some degree of mechanical fortitude because, after all , it is a safety item. Any reputable repair facility is going to back up their work with some kind of guarantee. There's also a broad aftermarket for brake components and many independents will use them. Not that that's really a bad thing because the quality of many of those parts either meets or exceeds OE. Personally, I'm biased towards Centric brand brake components because they work well on every vehicle I've used them on, foreign or domestic. Centric's 120 series brake rotors have a durable, anti-corrosion coating on the non-contact surfaces and their Posi-Quiet Ceramic brake pads typically include and required hardware...all at a fraction of the cost of dealership parts.
Old Mar 16, 2022 | 04:41 PM
CamryNerd's Avatar
I got Akebono brake pads and Centric rotors installed two weeks ago. Thanks!
Old Jun 1, 2022 | 01:15 AM
kdskamal's Avatar
I always buy OEM brake pads from a 3rd party vendor and get them replaced by my local mechanic.
Paul79UF
Nov 13, 2021 08:26 AM
cmk033
Dec 8, 2020 02:14 PM
cmk033
Jan 11, 2017 10:20 PM
hellozaizai
Aug 12, 2013 04:10 AM
teheeg
Jul 17, 2010 05:01 PM
