camry is to low
Old 11-21-2007, 09:28 AM
camryd3's Avatar
Default camry is to low
does anyone know ofany like lift kits or stiffer spring for my 99 camry. i haveoem suspension not lowered at all, i have new rims but they raises me up half an inch up,i just replaces all 4 struts about 3 months ago becasue i thought that was the problem. i have no subs in the trunk for added weight, but if i have anyone in the back seat i do nothing but scrapping all day. and all that rubs is my back end, my front for some reason has no problem. the part that is odd to my dad and me is that back end sits higher than the front does
Old 11-21-2007, 02:54 PM
5bucks's Avatar
Default RE: camry is to low
First off, what rims have you put on the car and the size? what tires and size.
You can't go over 1/2" from OEM the tires will matter as they are sized by hieght and wall height.
Old 11-21-2007, 08:12 PM
camryd3's Avatar
the tires are 235/45/17now the stock tires 205/65/15 are about 1/2 or less taller than the new 17s. i just got an estemate from my shop they said my tires are to wide and to high for my car and for new custom spring to make my car not bottom out will be $950 installed and raise it about .5 to 1 inch
Old 11-22-2007, 05:41 PM
5bucks's Avatar
ORIGINAL: camryd3
That is your problem the width of the rims and tires. I am going to guess that your rims are 8" wide.
I had the same tire size and had lowered my camry 1.5" and yes it rubbed a little on the back right side.
I didn't like this as I usually have our daughter in the back and it would rub more. I talke to the supplier that said these were ok and they took the rims and tires back, This was done through the dealership and a aftermarket supplier. I now have 225/35/20 on 20" rims that are 7.5" wide and still have the lowering kit on, which includes shocks and springs for performance handling. My advice is to sell the rims and tires and purchase the correct sizes. Good luck let me know how it turns out. My pics are to big for the post but if you want one to see the results let me know your e mail address.
sjflyer
04-15-2015 11:16 AM
tomfrh
07-28-2008 09:34 PM
turtle02909
05-29-2008 03:45 PM
jpayne2000
10-29-2007 04:35 PM
darjevon
10-12-2006 02:28 AM
Quick Reply: camry is to low
