Old Sep 1, 2015, 03:43 PM
How-Tos on this Topic
Browse all: Steering & Suspension Guides
Print Wikipost
failing wheel bearing?
Old Oct 30, 2011 | 09:33 PM
  #11
tyrantfour's Avatar
Default Update
While driving under hard acceleration noise stops. As soon as you let off the throttle just a little. noise comes right back.
Old Oct 31, 2011 | 10:16 AM
  #12
Is the chassis moving up transferring weight to the back?
Old Nov 3, 2011 | 07:42 PM
  #13
tyrantfour's Avatar
hey sorry i have updated in a few days. there is some rear squat on hard accel but its quite minimal. i went to the local u pull it and got a nice and clean axle. the old axles boots were tore on both ends and after driving in rain, i poured some water out of the inner boot. its been repaired. i took the opportunity to play with the bearing. not good. it has one spot in it the has that growl ive been looking for. so for sure its a f*&Ked up wheel bearing. ill pull the knuckle and have a shop press new bearings in.
i do have one final question, what is the likliehood that i will have to replace the hub? the bearings are not so bad as to have any 12/6 play whatsoever.
Old Nov 3, 2011 | 08:46 PM
  #14
Unless the bearing seized up and the hub started rotating inside the race (you would know this!) the hub should be OK.
Old Feb 22, 2012 | 08:20 AM
  #15
jlga's Avatar
Please be aware this is not an isolated incident. I brought my car in 2010 - 2009 Camry and informed before purchase it was just the wheels and the road and I had to replace the front driver side wheel bearing in April 2011 & I am now having to replace the front passenger side bearing now. I reported it and you can to at (800) 331-4331 #4 I am trying to let as many people know of this issue for this could be dangerous if that tire comes off.
jbundy321
Jan 6, 2015 09:58 AM
FERGI
Mar 25, 2011 05:04 PM
nickf829
Oct 3, 2010 01:36 AM
E_S
Jun 20, 2008 02:13 PM
redmartin
Mar 5, 2008 10:03 AM
