lowering a 1998 camry
I havent done any suspension work myself, but i believe all you need to lower it is to swap the springs with lowering springs. This needs to be done professionally unless you have the special pressure clamps to compress the springs in order to remove the strut mounts. If so, you will have to remove the struts, compress the springs, remove the strut mounts, remove the springs, replace with the lowering springs, compress those springs, put back the strut mounts and re-install the struts. There are alot of knowledgable people on here so please let me know if im forgetting anything. Peace.
here is a link to B&G and Eibach lowering kits for the 98 Camry. Eibach is better, but the only thing is that it dosent tell you the lowering height on the page. I know that the Eibach Pro-kit stage 1 goes to 1.5. lowering kits
ps, I just went to the Eibach website and they only make one lowering kit for your car, the part # is 8249.140 but they only lower to 1.2
mikeynavy1
Jul 31, 2011 10:21 PM
Dmb4088
Mar 1, 2008 07:41 PM
MVS687
Aug 18, 2006 12:19 AM
