why is my front so high?
Old Mar 30, 2007 | 03:55 AM
notascraper's Avatar
Default why is my front so high?
ok i just bought some lowering springs to give my 92 Le a 1.8 drop all aroundbut for some reason my front tires dont tuck like the back?[&:]the front sits high like a buick on oversized wheels
Old Apr 16, 2007 | 11:51 AM
trd_camry's Avatar
Default RE: why is my front so high?
any update on this matter ? i'd think they would "settle" and lower a little or maybe intalled wrong
Old Apr 16, 2007 | 01:44 PM
nodrogkam's Avatar
thats actually what happens with lowring springs for the gen 3 or so i've heard. it maybe to prevent rubbing in front.
Old May 18, 2007 | 11:10 AM
thanks i kept hearing the same ima just take them off
Old May 18, 2007 | 01:54 PM
nodrogkam's Avatar
wow old thread, but yeah that is exactly what happens. You'd need adjustable coil overs if you wanted your front to tuck like the back.
Old Jun 13, 2007 | 10:45 PM
cajunman1021's Avatar
i have a gen 5 camry with tein lowering springs and it does the same thing.
Old Jun 19, 2007 | 06:16 AM
lavalleemike's Avatar
On a camry the front is higher than the back in stock trim. So if you change out the springs the front is still going to be higher than the back
Old Jun 28, 2007 | 01:43 AM
VVTi's Avatar
Tein also gave me a good drop.
Old Jul 10, 2007 | 07:16 AM
bassposse's Avatar
it also has happened in my gen 2 camry i dont like the look withthe front up higher then the back may i surgest you cut a bit off the front springs that will make it lower and i know alot of people say dont cut them but i dont see the problem i got a mate that did this to his car and has had no problems
dtbrown
Jul 1, 2007 02:39 AM
aebomb
Oct 10, 2006 05:27 PM
imbrushedred
Jul 7, 2006 12:44 PM
marc780
Apr 10, 2006 06:22 PM
