1991 Camry stalls
Old Nov 26, 2009 | 05:54 AM
thomasthomas1's Avatar
Default 1991 Camry stalls
The first 5 pages of this forum show nothing but drug information. I assume I can list my problem with my Camry so here goes.
1991 Camry LE occasionally tries to sputter and stall - just as if it was running out of gas. Occasionally does stall but starts right up again. I replaced fule filter and fuel pump but it made no difference. Any suggestions where the problem lies.
Old Nov 26, 2009 | 10:10 PM
T5shortblock's Avatar
seems like this is a ghost forum full of spam, I dont understand what is going on here? so much for looking for help...
Old Dec 6, 2009 | 10:54 PM
Joel_CA's Avatar
Do you have a normal high idle speed when starting the engine completely cold? Does the idle speed kick up a few hundred RPM when you turn on the AC? If you turn the steering wheel slightly a few degrees with the engine running, does the idle kick up a bit? If NOT- you may have a failed IAC valve (idle speed control valve). What you can try doing is removing the boot to the intake, open up the throttle by hand, and clean the area surrounding the throttle plate with decarb cleaner and a rag. Spray the cleaner on the rag and wipe- don't spray into the intake as directed my most aerosol decarb cleaner cans. This may prevent your stall out and smooth out your idle speed.
JJ
Old Dec 7, 2009 | 03:53 PM
Default Not a gas problem
I finally found a fuel pump gauge that worked and set it up in front of the windwhield so I could watch it while I drove. The fuel pressure is between 40 and 50 pounds and doesn't drop when the car acts like it is running out of gas so I guess I don't have a fuel pressure problem. My next guess is distributor cap and rotor. Anybody got a better guess?
Old Dec 7, 2009 | 07:15 PM
full house's Avatar
did you check if there are some leaks?
Old Dec 8, 2009 | 03:40 AM
Joel_CA's Avatar
Low fuel pressure would affect your engine in a high fuel demand situation such as wide open throttle or acceleration- not at idle. If you can keep the engine running by simply holding the throttle slightly open with your foot- you have an IAC valve problem. I'd suggest you start there first.
JJ
Old Dec 14, 2009 | 05:55 PM
JayP71's Avatar
I had a Windstar van that did this and it turned out to be an issue with the ECU.
arepeem
Aug 19, 2011 09:47 PM
yamaha405
Oct 15, 2007 03:57 PM
tkgtf
Oct 14, 2007 01:42 PM
Rolley Noodles
Apr 10, 2007 11:24 PM
89camry
May 1, 2006 03:10 PM
