95 Camry Issues
Old Oct 9, 2012 | 09:23 PM
lwcamry95's Avatar
Default 95 Camry Issues
i have a 95 camry le 4 cyl and i got real low on my gas to the point it acted like it ran out. i filled it up and it kept sputtering almost like i lost a cylinder and still does. it has a bad miss and when you hit the gas it loses power but still moves forward. i put new spark plugs in and they are running lean but ive also put a new cap, ignition button, fuel filter, o2 sensors, and coil on and still hasnt made an improvement. i need help and i dont have the money to take it to a shop. could it be the fuel pump?
Old Oct 10, 2012 | 11:56 AM
The pump is cooled by fuel, running too low on fuel can cause damage. Or perhaps an issue wit the fuel pressure regulator.
Fuel pressure should be 38-44 psi engine on or off with fuel pressure regulator vacuum hose disconnected. 31-37 with hose connected.
The is a small plastic box mounted on the passengers side suspension upper strut mount tower. Inside the box are electrical terminals. Jump the FP and B+ terminal and the pump should now run with the ign switch in the on position.
Old Oct 10, 2012 | 09:15 PM
full house's Avatar
It wouldn't cost you much if you just ask for diagnose on your Camry just ask for advice on the shop they won't force you to leave your car if you can't pay.
Old Oct 11, 2012 | 02:40 PM
lwcamry95's Avatar
where is the shreater vavle to check the fuel pressure?
Old Oct 11, 2012 | 08:30 PM
lwcamry95's Avatar
it was the plug wire got a bad one from the store!
Old Oct 11, 2012 | 10:04 PM
Great job!
Aug 14, 2015 06:31 PM
Hondasucks
Oct 10, 2007 01:15 PM
NickHatsis
Sep 27, 2007 09:10 PM
bradster
Aug 14, 2007 11:10 PM
jtherrell
May 28, 2007 08:45 AM
