97 camry door wont open..
Old Mar 10, 2012 | 07:59 AM
POKAROKA's Avatar
Default 97 camry door wont open..
I own a '97 camry, the front passenger door suddenly will not open. The lock will not unlock completly,and unable to open from inside door or out. Can somebody help me please ?1
Old Mar 10, 2012 | 11:08 AM
You tried both manual and electric interior locks?
If not most likely the electric door lock actuator is broken.
To gain access requires removing the door panel and the door be open.
If lucky an auto locksmith or body shop can use a tool to open the door. If the door can be opened remove the door panel before closing or don't close it until the problem is fixed.
The internet has lots of posts on replacing the actuator.
Old Mar 10, 2012 | 03:28 PM
POKAROKA's Avatar
Default '97 camry door problem...
Thanks toyomoho !! I'll keep you posted.
Old Mar 11, 2012 | 06:23 AM
POKAROKA's Avatar
Default Power Mirror
My power mirror used to tilt down in reverse,but not any more. Any suggestions ?
Old Mar 11, 2012 | 09:19 AM
What?
Old Mar 12, 2012 | 10:09 PM
full house's Avatar
that's strange, how can you get out and in if doors won't open and close?
Old Mar 13, 2012 | 05:51 AM
POKAROKA's Avatar
Hence the problem !!! I've tried every way i could to open the door with no success !! Both inside and outside levers wont catch ,it wont unlock.
Old Mar 13, 2012 | 09:57 AM
The power lock actuator may be bad.
To access requires removing the door panel, or perhaps a locksmith or body shop can use a tool open the door.
Old Sep 12, 2012 | 02:21 AM
staurthill's Avatar
Hi,.
Look for access holes with either round clear tape or black plugs covering them. Can't remember if your car has either. Otherwise, diligence and patience with a good steady hand.
locksmith boston
azizmak
Oct 12, 2012 10:28 PM
stormy76
Jul 20, 2010 06:40 AM
danewoodard
Nov 10, 2008 04:41 PM
azizmak
Aug 2, 2006 09:22 PM
cmrylovr
Jul 30, 2006 05:10 PM
