Broken Thermostat Housing stud dont know how to get it out
Old Dec 21, 2018 | 06:32 PM
1kk's Avatar
1kk
Default Broken Thermostat Housing stud dont know how to get it out
I dont have much room to work with to get the bottom stud out here is some pics
__________________________________________________ _
2004 Toyota Camry Solara SLE V6 Coupe 3.3L V6 5-speed Automatic
Old Dec 21, 2018 | 07:19 PM
There are socket type bolt removal tools. However there is not that much exposed stud to grip.
https://www.ebay.com/i/312272410029?chn=ps
https://www.ebay.com/p/Powerbuilt-64...6734013&chn=ps
Best way is to heat the stud until red with a oxy/acetylene torch. When the stud has cooled back to normal color, apply wax around the thread area to try to draw it into the hole.
If you can get the stud to rotate any amount, start using a penetrating fluid. An autotmatic trans fluid and acetone mix works well. Work the stud one way and another to loosen it up.
If no oxy torch try a hand propane torch to heat the stud and draw in the fluid.
If no torch try a small pipe wrench.
https://www.homedepot.com/p/RIDGID-6...1000/202826809
Vice grips might work be tend to just to round the stud as the teeth slip, making the stud even more difficult to grip.
Old Dec 21, 2018 | 07:59 PM
1kk's Avatar
1kk
Thank you for your reply it really helps a lot, but what do you mean by "draw it into the hole" and I have a few different pairs of vice grips, a one foot pipe wrench, I may have a 6 inch one. Would PB Blaster work?
https://www.ebay.com/p/Powerbuilt-648639-1-4-to-3-4-Stud-Extractor-Remover/1611851470?iid=183596734013&chn=ps
Old Dec 22, 2018 | 10:53 AM
Wick into the thread area around the stud.
PB blaster also OK but if heating don't catch it on fire.
The issue with vice grips is the teeth may not be sharp enough to really grip the stud. Need to get wrench super tight or it will slip.
Old Aug 7, 2019 | 09:08 PM
MikeLikesCars's Avatar
I would apply the heat to the housing, not to the stud. Remove as much of the surrounding stuff to gain a clear access to the stud and housing. If there is room, clamp on a vice grip plier and apply force while heating the housing. Don't burn yourself.
Mpav329
Feb 10, 2019 09:55 AM
KEVAUG
Nov 22, 2016 08:20 AM
millerboy
Aug 31, 2016 11:57 PM
Scrumpilump2000
Feb 1, 2012 10:46 AM
guerreraux
Oct 31, 2011 09:15 PM
