97 camry power loss gauges & windows
all started with rough idle and missing then codes 301/2/4 showed, so I replaced fuel filt, egr, plugs, wires, coil packs, tps, O2 sensor in exh manifold. I was able to drive but then it started having a shifting probem with 753 code. I then tested at the shift solinoid and it manually shifts ok. Now I have had alternator and battery replaced because the car shut off no power in battery, thinking maybe electrical may root cause, now the dash blows the 10 amp fuse and the regulator shorts out, and this happens when I shift the transmission manually. Is there anyone that can point me in the right direction?
97 camry electrical and other problems
Year of car?
Do the stop lights, Cig lighter ,
Check 40A AM1 fuse. There a window on the fuse to do this. Location may be in a fuse box behind ash tray/coin box on far drivers side of dash. This fuse bolts onto the fuse board and DOES NOT pull out. Need to access rear of board to remove.
szpta
03-01-2021 07:08 PM
