Clicking if key is removed
Old 12-15-2012, 05:22 PM
justinbrandi's Avatar
Default Clicking if key is removed
We have a 2002 camry, and if you take the key out of the ignition, there is a clicking that comes from the fusebox under the hood. If you leave the key in the ignition it doesn't click. The clicking drains the battery. Also, if you take the key out, but leave the drivers door open, it won't click. Does anyone have a clue about what might be going on?
Old 12-15-2012, 08:59 PM
If you can, open the fuse box and determine which component is clicking. They should be labeled. Then post back.
Make sure the ign key switch is turning off. With key out check all electrical items that are normally off when the ign key is removed.
ToyotaJay
06-06-2012 10:35 AM
ToyotaJay
06-03-2012 01:47 PM
red73mustang
03-26-2008 07:42 AM
tadder04
03-22-2008 01:10 PM
ttcmy17
02-21-2008 07:33 PM
Quick Reply: Clicking if key is removed
