Timing retards when jumper is removed
Old Jun 4, 2012 | 02:39 PM
ToyotaJay's Avatar
Default Timing retards when jumper is removed
1992 Camry 2.2 liter - - After setting the timing to 10 degrees btdc with the jumper (E1 to TE1) I remove the jumper and it should go up (12 degrees to 22 degrees) But instead it drops to 5 degrees btdc.
Why would it do this? and what problems could it cause?
Old Jun 5, 2012 | 12:06 PM
After jumper is removed timing should move between 0 and 10.
Old Jun 5, 2012 | 08:49 PM
ToyotaJay's Avatar
According to my manual it should move between 12 btdc and 22 btdc.
If you are correct then it is OK.
Old Jun 6, 2012 | 10:35 AM
Info per Camry shop manual.
If engine idles and runs OK, then timing should be OK.
sknutson
Nov 7, 2013 07:28 PM
sknutson
Nov 6, 2013 09:07 PM
justinbrandi
Dec 15, 2012 08:59 PM
ToyotaJay
Jun 3, 2012 01:47 PM
oldad
Jan 7, 2012 07:28 PM
