Compression Test
Old 02-13-2017, 05:56 PM
Elkhuner12's Avatar
Default Compression Test
Ok, I have a 1993 Camry with the 3.0 V6. I did a compression test today because the person I purchased the car from said it needed a head gasket. There was no water in oil and I haven't seen any other leaks. I did a dry and wet test. The results of the dry were #1 155, #2 151, # 3 153, # 4 151, # 5 155, and #6 155. The wet test was #1 181, #2 178, #3 177, #4 182, #5 175, and #6 208.
Pretty consistent, but I was wondering what someone with experience with this engine might think?
Old 02-13-2017, 07:12 PM
mothorton's Avatar
I don't know why you were told that the engine needs a head gasket.... a brand new one off the showroom floor probably wouldn't do much better! Just to convince yourself, do a cylinder leakage (leakdown) test with the radiator cap removed.... if a head gasket is blown on any cylinder, when you put air to that cylinder bubbles will be seen in the radiator neck and coolant will be pushed out of the radiator.
Old 02-13-2017, 07:57 PM
Elkhuner12's Avatar
Thank you Mothorton!
Old 02-13-2017, 08:55 PM
dirty hands's Avatar
cant say it has a head gasket problem on those figures
for example the1MZ-FE V6 spec is 178 psi (crank over speed )
and its cylinder compression variation allowance is 14 psi
if that engine has done a lot of mileage/ km .. I would be happy with 155 cold start
on your readings would say bit of leaky valve and a little worn rings on all
brett
01-27-2016 01:02 AM
1989_Camry
01-02-2015 12:51 PM
91prizm
10-08-2011 10:05 PM
brett
03-19-2008 11:18 AM
MTPolaris
09-28-2006 04:21 PM
Quick Reply: Compression Test
