Sponsored by:
Sponsored by:
Fuel tank flush?
Old 01-31-2009, 01:29 PM
thecaveboy's Avatar
Default Fuel tank flush?
I somehow got water in my gas tank back in aug 08 ruined the fuel pump/filter the mech. said you should replace the filter in 10k , well waited too long. It wont run took filter off rust in the line mix with the gas saw it once the spilled gas evaporated, musta it clogged it up. Any thoughts on whats best step. replace tank or just flush, put new filter on keep on rolling? etc...
95 dx 4cly. 2.2
Thanks
Duane
Old 01-31-2009, 03:40 PM
pedro's Avatar
Looks like your identical post on Toyotanation will get you an answer- don't waste our time.
Old 01-31-2009, 05:41 PM
thecaveboy's Avatar
Default follow up
I do use both fourms and follow up on both, so I don't believe i am wasting time just reaching more.
I took the filter off and rust was in it, i put a clear glass one inline too and will leave it on for a while so I can see whats coming thru the line. it was flowing pretty clean so I am going to just watch it for a while. Its running!
http://picasaweb.google.com/therealcaveboy/Camry#
Old 02-03-2009, 10:15 PM
thecaveboy's Avatar
Default tank flush
It ran for a down the street but stalled out in the drive way I think the injectors are clogged anyone ever romve them? Is it difficult?
Old 02-03-2009, 10:17 PM
05cam's Avatar
get a haynes manual youll be glad you did
Old 02-03-2009, 11:48 PM
The Autozone website may have info on removing the injectors. Not to hard but you will need new injectors O-rings.
Suggest you do a complete fuel system clean.
Did you replace the can fuel filter in the engine compartment?
joelvv
05-30-2011 12:09 PM
mrmattwynne
05-11-2011 01:44 PM
big d
06-03-2009 07:20 AM
93camryxle
02-13-2009 09:35 PM
gslrider
06-26-2008 02:55 PM
Quick Reply: Fuel tank flush?
