Sponsored by:
Sponsored by:
hooked up jumper cables the wrong way
Old 11-28-2015, 01:05 AM
thetripler's Avatar
Default hooked up jumper cables the wrong way
Hey everyone. So I had a bad morning about 2 weeks ago. My 2007 camry le v6 had a dead battery. I jumped it with my 98 & hooked up the jumper cables the wrong way. My 07 started but the cel was on & I had no throttle. It would still go into gear & move but only at an idle. I took it to my mechanic where it has been since. He said it's now turning over but not starting. Could I have fried my computer or do the 07s have a safe mode or limp mode? Any help would be greatly appreciated. Maybe it's possible that my mechanic is over looking something simple. Thanks in advance
Old 11-28-2015, 01:43 AM
dirty hands's Avatar
usually the heavy fuses blow in the engine bay ... thats its safety
the ecu may have its own fuse
if all the fuses are ok
swap out the ecu with the correct one see if it starts
dont know if that model includes the tranny control in its ecu or if it is a separate unit
Old 11-28-2015, 02:12 AM
thetripler's Avatar
I don't know what my mechanic checked yet. I've been busy since it's been there. If it's the case Is a new ecu expensive
Old 11-28-2015, 02:39 PM
these camrys have a diagnostics port for your mechanic to retrieve fault codes
should be obd 2 codes
here is the list
http://www.obd-codes.com/trouble_codes/
with these codes you can narrow down the problem... before buying un-needed parts
ECU... no not usually expensive . but it is an import.... might be harder to find the correct one
ring around your local area and state for a car wrecker that has toyota camrys
you have to ask for the exact one out of a 2007 camry le v6
Old 11-30-2015, 02:58 PM
Usual it is a fuse and not the ECU. Take note the anti-theft system may activate if the battery is disconnected. This will prevent the engine from starting.
The ECU has a part number on it such as 89661-06C40. If needing a replacement get one with the exact same part number as the one on the car. There is an active reselling market for used ECU's. Also try Ebay.
Old 11-30-2015, 03:14 PM
thetripler's Avatar
Thanks a lot guys for all the feedback. Just got my camry back, was just some fuses. Makes me very happy lol. Thanks again guys
Old 12-01-2015, 09:25 PM
coldburn92's Avatar
Great to hear its an easy fix for you. Happened too to my brother's '06 rav4 with toasted fuse.
sknutson
11-07-2013 07:28 PM
sknutson
11-06-2013 09:07 PM
ToyotaJay
06-03-2012 01:47 PM
Cartercao
08-31-2010 10:35 PM
santolucha
01-23-2007 12:38 AM
Quick Reply: hooked up jumper cables the wrong way
