Sponsored by:
Sponsored by:
Old 08-26-2015, 01:59 PM
How-Tos on this Topic
Browse all: Lighting Guides
Print Wikipost
Lamp Failure Sensor/Switch
Old 03-05-2005, 01:57 PM
pjmcshea's Avatar
Default Lamp Failure Sensor/Switch
Regarding previous post. I obtained two such devices from a junkyard. $10 . Problem fixed! (I had a series of problems.. first the tailight . then the stop light.. prior stoplight portion of trunk.. All fixed with replacement part! Parts houses couldn't even find it in the books. On line parts couldn't find it. Toyota said it would cost $190.00! Junk yard didn't know what it was or where it was.. I went with them and got the part. Its under the lining above the left rear wheel.
Old 10-20-2009, 10:00 PM
Antroxu's Avatar
I own a 1986 Camry and I've had the same problem. However, in my car the lamp failure sensor is located on the right side, inside the trunk, above the right rear wheel, underneath the lining and behind a side metal body piece, but not hard to find it.
sestivers
12-22-2022 12:03 PM
Lovehatetony
10-21-2011 10:05 AM
kovi32
02-07-2009 02:44 PM
oxymoron
08-29-2007 09:37 AM
pjmcshea
09-06-2005 03:29 AM
Quick Reply: Lamp Failure Sensor/Switch
