moonroof open warning
I am getting a "moonroof open" warning. The moonroof is not open and will not open. Any clues?? 07 Camery.
I have had very bad expereince with the electronics. The radio shuts off when switching between bands. The a\c has mind of its own.
Thanks
Thanks
RE: moonroof open warning
ORIGINAL: bosulli
Based solely on the limited description of the problems that you described, I would suspect one orboth of the following components as the culprit:
-alternator
-ECU
It's a good thing thatit's still covered by the mfr. warranty sincediagnosingelectrical-relatedproblems can get quite involved and expensive.
I have 65k miles on it. So, I do not think warranty is still in effect.
The warning light says moonroof. Go figure.
I will check the fuse, but I would think that other things would not work.
I was hoping this was a common problem with the Camry, but I guess not.
Thanks for the replys.
ORIGINAL: bosulli
ORIGINAL: bosulli
MOONROOF OPEN warning light 2007 Camry
This light comes on as soon as I open the door and then goes off. The moonroof, which I have not opened in months (or years) is closed and will not open. I saw this topic was discussed in 2008 but I did not see a final remedy or even a diagnosis. Any ideas?
