Sponsored by:
Sponsored by:
V6 camry oil leak 1996
Old 02-08-2011, 04:53 AM
matt xj's Avatar
Default V6 camry oil leak 1996
hello i have a 1996 v6 camry that leak engine oil the problem is when i have driven the vehicle and turn the car off, engine oil leaks at the front of the engine leaving a puddle, i stripped the front of the engine down think it was the front oil seak and it is dry so is the timing belt, has anybody a clue what it could be maybe the oil pump ?
thanks
Old 02-08-2011, 01:39 PM
Front as in side of engine facing the radiator or side having the timing belt.
Oil pump is behind the crank pulley and turned by the crank. The crank seal is the oil pump seal.
Old 02-08-2011, 05:29 PM
matt xj's Avatar
okay, the front meaning the front of the engine. i can not seem to trace where is it comes from it just very wet in the area
Old 02-09-2011, 12:13 AM
There is not much to leak on the front of the engine.
Have you checked the oil filter, perhaps the gasket has problems, on rare occasions the thread on the filter is bad, etc.
The valve covers gaskets can leak, a very common problem.
The oil pump is in a large housing bolted to the side of the engine where the timing belt is. Check the gasket between the housing and block, leaking in this area has never been a problem but?
Old 02-09-2011, 05:25 AM
matt xj's Avatar
thanks i will have another look and let you know how i go.
i will have a look on saturday
vincent52100
05-10-2011 10:34 AM
the dark sailor
05-03-2011 10:25 AM
LAROCK
10-24-2009 09:05 AM
lesaroka
09-12-2005 10:58 PM
Quick Reply: V6 camry oil leak 1996
