ABS kicks on for no reason. 99 4cyl LE
Old 03-07-2017, 11:29 AM
frankjc's Avatar
Default ABS kicks on for no reason. 99 4cyl LE
Occasionally, my ABS kicks on for no reason. Usually when coming to a stop, it will kick on just before the car stops. Odd...
My plan is: Pull off all 4 wheels, check the abs rings, make sure sensors are clean. Check all connections.
I tried to pull codes with a jumper wire using instructions I found, and couldn't get any codes, the light just flashed fast.
Any suggestions?
Old 03-08-2017, 01:51 AM
It sounds like you have a pretty good plan in place. The sensors seem to be messed up.
Getting the code read would be my only suggestion as it might narrow down the hunt.
Old 03-08-2017, 10:10 AM
Ditto on sensor issues.
Try cleaning them and the ABS signal rotor (tone ring). Check the gap between the ring and sensor and make sure one is not larger/smaller then the others.
Arky
11-16-2019 08:38 AM
Vietballerz
06-08-2010 03:51 PM
Allan
05-20-2010 09:33 AM
granadaCoder
07-29-2008 12:43 PM
Quick Reply: ABS kicks on for no reason. 99 4cyl LE
