06 le brake issue
Old Aug 19, 2020 | 09:43 PM
tree75's Avatar
Default 06 le brake issue
I installed power stop rotors a pads on front wheels. Wasn’t having any problems but car has 142000. I bought it new. Steering wheel and left to right is good. When I use brake pedal light to medium it’s great, but if I depress pedal a little hard or quick it pulsates. I put on speed bleeders and replaced brake fluid without letting master cylinder get low. I replaced rear drum rotors and shoes at same time. Master cylinder not showing any leaks. ?????t
Old Aug 20, 2020 | 09:46 PM
Did the problem start right after the brake repair?
Old Aug 20, 2020 | 09:52 PM
tree75's Avatar
Yes. I did the recommended breaking procedure, so it’s been a week or two since I did the work, but yes it didn’t have the problem before.
Old Aug 21, 2020 | 01:26 PM
Given the problem started right after the change assume the suspension is OK.
Is the problem limited to brake pulsation or does the car also have steering wheel shake under hard braking?
If only pulsation it could be too hard of brake pad which amplifies variations in rotor thickness. I always suggest Toyota pads. They cost more but have always been problem free.
Old Aug 21, 2020 | 11:17 PM
tree75's Avatar
I will install Toyota pads and let you know the results. Thanks for your help.
Old Aug 29, 2020 | 09:08 AM
allserene's Avatar
It isn't the ABS cutting in too soon and pulsing the brakes is it ?
Old Sep 21, 2020 | 09:08 PM
tree75's Avatar
Conclusion. I installed Toyota OEM front rotors and pads. The problem was still there. I then installed Toyota OEM rear drums and shoes. Problem completely was solved. Brakes are super smooth. Like brand new for real. So I guess I won’t be buying lesser known cheaper parts. It’s just not worth the trouble. If I do buy aftermarket, I will need to stay with Ac Delco or Dorman,,,, etc.
Old Sep 22, 2020 | 03:19 PM
Thanks for the update.
Hocky201
Sep 9, 2018 06:26 PM
OldGuy
Jul 17, 2013 06:14 AM
surajjohn29
Mar 16, 2013 04:11 PM
dingo77
May 25, 2009 07:40 PM
bobby112
Apr 17, 2008 12:30 AM
