1987 Various items
Old Aug 12, 2019 | 04:43 PM
  #11
kampy's Avatar
Is this a Canada car?
If not, the headlight switch grounds the high or low beam filament wire. Try using an ohm meter to determine if affected bulb filament (high/low) ground wires are actually grounded when you have these headlight issues.
It is not a Canada car. I metered socket to socket and had continuity, and had the grounds when I was supposed and the drivers side worked ok unless the passenger side was plugged in.;
I seems like a ground issue because my test light would glow dimly on the high beam circuit. It's looking like a ground problem which is why I was wondering of there was anything else in the ground path beside the headlight switch.This may be a switch problem too. I might get a couple of days with it in the next week or so to investigate further.
Electroman
Oct 1, 2019 03:03 PM
foxyroxy111298
Nov 6, 2011 08:44 AM
larrys
Jul 30, 2011 10:45 AM
hashubek
Sep 1, 2008 11:46 AM
59coop
Jul 14, 2008 12:41 PM
