1989 Camry 4 cylinder spark plugs
Old May 13, 2017 | 02:25 PM
1989_Camry's Avatar
Default 1989 Camry 4 cylinder spark plugs
Hi,
How often should I change spark plugs?
Should I just use the regular/copper plugs, or should i use platinum or iridium?
thanks!!!!!
Old May 13, 2017 | 05:40 PM
Suggest Denso brand platinum. Platinum can last 100K miles. The extra cost of platinum plugs is minimal verses copper and they last a lot longer.
Old May 13, 2017 | 06:07 PM
1989_Camry's Avatar
Thanks. Do platinums need to be re-gapped?
I use about 1/2 quart every 1,000-2,000 miles. There is no change in mileage or check engine light on. I just checked the exhaust and there is no smoke.
However, I just regapped my spark plugs, #1 and #3 threads have fresh oil. What does that mean?
Old May 14, 2017 | 11:38 AM
Depends on what the manufactured plug is gaped at. If gaping only move the ground electrode and don't apply pressure on the center electrode. Use a gaping tool.
Most owners never gap a plug.
The threads of 1 and 3 have motor oil on them?
Use a flash light and check for motor oil getting into the spark plug tubes. The tube is pressed or screwed into the head and can leak.
Unless there is a lot of oil in the tube as in getting onto the spark plug socket, would not be concerned.
ShiftAce
Sep 12, 2022 10:56 PM
james007
May 22, 2012 07:06 PM
tukkus
Apr 18, 2011 10:00 PM
ssj4goku
Feb 16, 2010 05:38 PM
sharmve
May 9, 2008 11:01 AM
