2003 camry timing chain
Old Oct 5, 2016 | 08:16 PM
sealowk2's Avatar
Default 2003 camry timing chain
this is an update on mine previous post. 2003 camry timing cover repack. The first time I did not put the engine on TDC. The 2nd time I did the proper timing marking, without removing the timing cover and the chain tensioner. I did rotate the damper CW until I got the correct marking. The movement of the damper felt smooth. Now the engine will not start. I sound like the starter is not aligned with fly wheel. Did I damage those parts or misaligned them while lifting the engine. Could someone advise me.
Thank you and be safe
Old Oct 5, 2016 | 10:23 PM
dirty hands's Avatar
starter motor looks like a hi torque type
the battery might be a bit flat after all that cranking and no start or charge
will make starter sound different
check starter motor is flush with the housing no gap at the holding bolts
mrfixit
Jan 13, 2016 03:24 AM
cachetopia2
Jan 12, 2016 04:02 PM
rick oshay
Jan 7, 2013 12:22 PM
JNichols
Aug 13, 2009 06:46 PM
surfsalterpath
Oct 9, 2007 09:06 PM
