2004 Camry Oil Pan thread
Old Aug 15, 2012 | 08:52 PM
kamyx's Avatar
Default 2004 Camry Oil Pan thread
So i stripped my oil pan thread and went to napa and got a oversized self-tapping piggyback plug. I pretty much know what to do but after like 1 1/2 hours i could not get the damn thing to screw in. It fits in the hole but its impossible it feels like to get it to cut new threads. Should i be using a drill or something?? I was using my hand till i got it to stay then tried a wrench on it but it kept falling out.
THanks
Old Aug 15, 2012 | 09:12 PM
full house's Avatar
Does your wrench is working perfectly? try to use fliers or anything that can help loosen or tighten it up.
Old Aug 15, 2012 | 09:51 PM
kamyx's Avatar
well ya im just using a regular 18mm wrench, loosening is not a problem, im having trouble getting the new threads started. Do i just need to muscle in that bitch or is there something im missing
Old Aug 15, 2012 | 11:19 PM
Did you get the right size plug? There are also metric and English thread plugs.
If you can't get the plug to start self tapping the existing hole is too small (or new plug OD too large) or you need to apply more thrust when turning the plug.
If possible compare the thread OD of the replacement plug to the old plug.
There are metric oversize thread plugs.
Old Aug 16, 2012 | 04:06 PM
kamyx's Avatar
they are both m12-1.25mm except 1 is oversize of course. So im positive i got the right one, it goes into the hole, im gonna try again right now and attempt to put more pressure on it. Im not using a socket wrench however just a regular box(?) wrench. Also i heard putting grease on the plug will help so ill try that
bigmo5328
Jun 28, 2015 10:33 AM
cad1292
Jan 7, 2012 11:44 AM
a_do_not_knowcargirl
May 27, 2011 04:01 PM
ireneki
Jan 31, 2009 10:29 PM
jones100001
Dec 8, 2008 08:38 PM
