2009 camry my driver side low bean bulb won't work.
Old Feb 14, 2012 | 08:36 PM
mannyfresher22's Avatar
Default 2009 camry my driver side low bean bulb won't work.
I have changed the light bulb and it still won't work. is there a fuse for each light bulb? can someone help?
Old Feb 14, 2012 | 11:50 PM
There is a fuse box inside the engine compartment, left side.
Look for fuses labeled H-LP then LL or RL for lower left or lower right
Old Feb 15, 2012 | 10:37 PM
ukrkoz's Avatar
you may have bad socket, and it can be replaced.
you may have blown fusible link in wire. good luck.
you do not have per light bulb fuses.
on my wife's RX300, high beam on pass side does not work. who gives. has no power to it.
you can run parallel wire from working light wire. I have that on my son's Eclipse for about a year now. works.
Old Feb 16, 2012 | 03:38 AM
Thanks joey. It was a fuse that was out. thanks for your help.
Old Feb 16, 2012 | 12:06 PM
Great!
Old Feb 16, 2012 | 09:09 PM
full house's Avatar
that's great! you bought new fuse or you fix it?
Old Feb 17, 2012 | 03:23 AM
My car came with spare fuses so i didn't have to buy one. :-)
Laserbeast
Jul 17, 2013 09:49 PM
toyota2000
Jan 10, 2012 01:06 PM
MattS67
Jan 12, 2009 09:59 PM
