the driver side from the front wheel LOW rather than the passnger
Old Jan 2, 2012 | 03:46 PM
toyota2000's Avatar
Exclamation the driver side from the front wheel LOW rather than the passnger
I have 2000 toyota camry 4 cyl
its 76,000 miles its excellant condtion
recently
i feel the driver side from the front wheel low rather than the passnger
i went to check it if it need alighiment but then result "alighmnet is complince with manufacturing company"excellent the car does not need alighmnet and there is No sound from them..
is this from the shocks or springs??
Old Jan 3, 2012 | 12:50 AM
Compare distances between a point on the chassis and ground for each side of the car.
Using steering wheel rotate the front of each front wheel fully outward one at a time then look at the suspension to determine if the issue is the lower suspension or upper strut portion.
A strut can have a broken or sagging spring.
Old Jan 3, 2012 | 11:40 AM
toyota2000's Avatar
its saggin not broken and when you drive you dont feel it but i feel it cozm i no my car very well ,,when i did what you say,,its lower little abit,
do u no what i have to do for them?where the best to go in auto zone or the dealors? thanks
Old Jan 3, 2012 | 12:15 PM
Would be best to remove the tire and inspect the suspension completely. If uncertain what to look for compare the passenger side with driver side and not any differences.
If you suspect a sagging spring a Google search will produce hits for sites that sell springs.
Dealer could order part but most likely much more expensive.
If going to Autozone call first to make sure they can obtain the part, they don't seem to list a front spring at their website.
Rockauto.com has a selection of springs at their website.
2000 TOYOTA CAMRY Coil Spring
Old Jan 9, 2012 | 02:16 PM
toyota2000's Avatar
Default i fixed them
i took off the tire from the driver side,at the first seen you don not notice any thing,but when i checked twice ,i saw the springs cyrcles tired and close together ,i remeber before one month wen i hit the edge of the street by this wheels and its happend flat tire..
i orderd two springs for the driver side and to other side from AUTO ZONE abou 50 bucks each,,and i sent them to the mechanic and he fixed them,,
now i feel good,,i did not chaged the shocks ...only i changed the springs..
Old Jan 10, 2012 | 11:33 AM
Great job!
Old Jan 10, 2012 | 01:06 PM
toyota2000's Avatar
thank you Toyomoho
mannyfresher22
Feb 17, 2012 03:23 AM
wennis1
Nov 23, 2011 08:57 AM
stouto
Aug 5, 2011 01:12 PM
sdbrown
Jan 17, 2011 05:47 PM
53burb
Nov 4, 2006 08:01 PM
