98 fed engine into 99 cali car
Old 04-07-2021, 07:13 PM
cullenbeemer@gmail.com's Avatar
Default 98 fed engine into 99 cali car
I am putting a 1998 federal engine into a 1999 California car. Will be using wiring harness, exhaust manifold and engine control unit from the federal engine.What else will I have to do to make everything work properly?
Last edited by cullenbeemer@gmail.com; 04-07-2021 at 07:23 PM. Reason: add more information
Old 04-07-2021, 07:58 PM
What engine type?
Why are you using the 98 wiring, etc and not modifying the 98 to a 99 using the 99 parts?
Old 04-07-2021, 09:41 PM
I bought this 1999 Camry with a bad engine.The 2.2L engine(120,000 miles) with California emissions spun a bearing. I bought a 1998 2.2L used remanufactured low milage engine with federal emissions which included complete engine wiring harness, complete intake, exhaust manifold. I am swapping the engine and computer(computer was on the car the engine came from).Are there any other problems I will encounter with this project?
Old 04-08-2021, 05:52 PM
Engine wise should be OK if you do as stated.
Take it the trans was automatic in both cars.
The 98 and 99 engine/trans/emissions for the 4 cylinder appear to not have changed between years.
Old 04-08-2021, 05:59 PM
Default Thanks!
Yes, they are automatics.Thanks for the support.
t.mcginley.jr
08-13-2014 12:09 PM
995sfe
10-06-2011 09:44 PM
nwstehle
07-27-2011 07:41 AM
khays
07-06-2008 09:51 PM
Quick Reply: 98 fed engine into 99 cali car
