Brake help, pad fell out while driving
Old Apr 4, 2011 | 02:41 PM
kmckinney0126's Avatar
Default Brake help, pad fell out while driving
89 Camry 4 cyl auto, 180000.
Drivers side was fine, even wear, 1/4 in pad left, caliper good conditioon.
Passenger side was where the pad fell out. piston on caliper was damaged, would not compress. Replaced caliper.
When bleeding the passenger side the piston will not expand. No fluid coming throug brake line, but seems like there is a little air.
Any ideas?
Old Apr 4, 2011 | 04:35 PM
Station wagon?
ABS brakes?
Did the fluid level in the master cylinder ever run dry?
Old Apr 4, 2011 | 04:39 PM
seth jon's Avatar
Any ideas?
Sounds like the rotor has been turned too many times and is too thin. What may be happening is that the piston is actually out more than it should be and VERY soon will pop out completely while driving and then you will have no brakes.
Old Apr 4, 2011 | 05:07 PM
correction, 98 not 89.
Cannot get steady flow of fluid to passenger side.
Removed rubber hose and tried bleeding straight from steel line. Can feel and hear air moving through but only sputtering fluid. Driver side bleeds fine...
Old Apr 4, 2011 | 05:10 PM
yes abs. I dont believe mc went dry.
Old Apr 4, 2011 | 05:44 PM
If the master cylinder went dry, air gets into the system then the cylinder would require bleeding.
Are you using a check valve or something to keep the air that is coming out from going back in when you release the pedal?
KEVAUG
Mar 16, 2012 09:46 AM
Specvern
May 17, 2011 08:58 AM
teheeg
Jul 17, 2010 05:01 PM
JCOLON81
May 19, 2010 09:16 AM
trdcamrygracia
Nov 3, 2007 01:38 AM
