Electrical problems
Old Sep 26, 2011 | 07:34 PM
  #11
The link below provides more detailed info on how the alt works and how to test it in detail.
http://www.autoshop101.com/forms/h8.pdf
If you look at the wiring diagram the engine controller is not in the circuit. The alt is basically isolated and via the alt regulator takes care of itself. The ign key turns the alt on.
Wonder if the alt is putting out too much current.
Check voltage at the red/green wire as the engine dies and determine if the voltage drops significantly.
Suppose you could bypass the ign switch. Run the red/green and yellow wire alt connections from the alt to the battery direct. This would remove out any of the cars other electrical circuits.
Old Sep 29, 2011 | 08:25 PM
  #12
tomm's Avatar
I haven't even made up a whole new wiring to the alternator, from the battery just to try to see if the problem was in the harness between the battery and the alternator I ran the big charge wire and the three little regulator wires direct to the battery and the problem remains. When the engine still quits the ignition coils still have 12 V going into them with the motor quits I also checked out the injectors that they still have 12 V going into the injectors . It seems like with the engine starts up and the alternator starts charging above 13 V the engine starts to shut down.
glaze417
May 2, 2014 09:54 AM
efleon
Jun 18, 2010 04:45 AM
edcamry
Dec 21, 2009 11:13 AM
jeeperman
Oct 27, 2008 08:19 PM
TOTALXTC
Apr 10, 2006 10:36 PM
