idle problem soothed by unplug purge valve hose to throttle body
Old Oct 19, 2023 | 07:28 AM
  #41
pandaii's Avatar
injectors. I found the o-ring broken several time, but yesterday, o-ring was still good. So I changed thicker o-ring, which usually would broken, but not definitely leaking.
Old Oct 19, 2023 | 08:25 AM
  #42
Are you using the correct o-rings?
Old Oct 23, 2023 | 07:07 PM
  #43
pandaii's Avatar
I think so. But now I used somewhat larger, it seems work. If I find it not work again, I would consider using lubricant.
Old Nov 14, 2023 | 11:09 AM
  #44
pandaii's Avatar
Bull****, code P0172 came back again, clueless. Not significant idle problem, no stall, though turning rate slightly waving.
p
PeteWinter
Jan 19, 2024 10:48 PM
sgpilot
May 30, 2013 10:22 PM
tzchaiboy
Jan 15, 2013 05:12 PM
weinerrichard
Aug 9, 2010 06:21 PM
KennyCoe
May 10, 2009 09:29 PM
