Power Steering
Old Jan 30, 2018 | 01:04 PM
James3201's Avatar
Default Power Steering
I have a 2007 Camry SE, and a slight Power Steering leak. It is coming from the return hose on the Power Steering Reservoir right were the retaining clip is. I don't need the whole tube, just the short rubber hose, but am unable to locate a part, and or a replacement that is suitable for it. Does anyone have any ideas, or can point me in the right direction? I found the whole line on Rockauto.com for $44.79, but I think that is a little much for just wanting to take the rubber section off it. Alternate/OEM Part Number(s): 4440606171
Old Jan 30, 2018 | 02:55 PM
Most likely you will not be able to find a preformed replacement hose.
There is hose designed for oil coolers/power steering applications.
The hose sold based on internal hose diameter and by the foot.
The hose pictured appears to be a low pressure power steering return hose. This makes difference in the type of hose used.
Measure pipe OD to get the correct hose size.
Shop auto parts stores.
erbrian
Nov 13, 2016 01:36 PM
bassboobs
Jan 3, 2008 03:30 PM
Black95Cam
Sep 6, 2007 11:42 AM
oglaughzalotzz
Apr 23, 2007 04:12 PM
oglaughzalotzz
Apr 15, 2007 10:03 PM
