Rear Main Seal
Old Oct 21, 2017 | 11:43 AM
Trutt's Avatar
Default Rear Main Seal
Hi everyone, I have a 1996 Toyota Camry with a 2.2L 4cyl. Automatic. I recently did the rear main seal on it with no issues. However, I am currently putting everythingback together with a little difficulty. When I removed the transmission from the engine I had trouble removing the passenger side CV Axle. The bearing that runs through the motor mount is sezied. So what I did was remove the rear engine mount. Now, as everything, is coming back together, that's part of the problem. I cant seem to line the engine, transmission, or rear motor mount to bolt anything back together. Any suggestions? I unfortunately dont have an engine crane or anything similar. I've done everything on jack and jack stands.
Old Oct 21, 2017 | 06:42 PM
Is the trans bell housing fully engaged to the engine (no space between the two)? If there is a space, don't try to snug it up! Post back first.
Can you line up and engage the trans mount as a reference point? Then the front mount. Then work on the rear.
runner5113
Feb 10, 2011 10:43 PM
surfer
Aug 16, 2010 07:48 AM
ldballoon4
Apr 26, 2009 09:50 PM
StoreKeeper
Jan 2, 2008 06:39 PM
blackCam99
Jul 13, 2007 12:43 PM
