Removing heads on 1992 Camry V6
Old Dec 10, 2015 | 02:12 AM
Ferrance's Avatar
Default Removing heads on 1992 Camry V6
Several questions: How do I remove the bracket in front of the water pump and the exhaust manifold near the firewall? There doesn't seem to be any room to work against the firewall. Also, is it necessary to remove the crank pulley to replace the water pump and the timing belt?
Many thanks!
Frank
Old Dec 10, 2015 | 08:05 PM
Review the link below on removing the bracket.
DIY: How to replace a timing belt on 1MZ-FE
The crank pulley needs to be removed to remove the timing belt cover.
bushyone
Oct 30, 2011 12:20 PM
camryisondeathbed
Jul 22, 2009 07:23 AM
Jaybird9
Jun 4, 2007 02:27 PM
hlavender
May 21, 2007 08:41 PM
sl1solo
Aug 20, 2006 03:12 PM
