Rocker Panel Rust Question
Old Oct 11, 2017 | 10:48 AM
wdc123's Avatar
Default Rocker Panel Rust Question
Quick question on rocker panels. Its not a camry buy need some advice.
I have a 1999 Ford Contour SVT that has rocker panels that a rusted out fully both sides and even difficult to jack due to rust. The Rocker panels provide support for the middle body and would be dangerous to drive and not worth fixing since there is rust in other places. Going to part it out. Does that make sense? I placed the jack in its jack spot and jack sunk into underside after a week.
Old Oct 12, 2017 | 07:03 AM
wdc123's Avatar
After some research found out since this is a unit body and its part of the frame badly rusted out of rockers panels are unsafe. If in an accident the car could fold in the middle and the support of the middle of the car is in question. It would be different if this was my 2003 suburban since it has a frame support.
Old Oct 12, 2017 | 11:55 AM
Rusted rocker panels (typically from road salt) are common. They can be repaired.
The chassis is basically stamped sheet metal spot welded together.
Rust can degrade the crash protection of the car. How much depends on the location and amount of rust of course.
Old Oct 12, 2017 | 12:34 PM
wdc123's Avatar
Thanks, Its rusted through the rocker panels and then some plus there is a lot of underbody rust unlike my camry which has some rust but not structural at all. They really undercoated the camry well and has minimal rust overall.
restore
Jul 25, 2010 05:57 PM
stick
Mar 28, 2009 12:02 PM
cg22
Aug 24, 2008 10:04 AM
GTScott
Feb 25, 2008 11:29 AM
Dan_Lemur
Jul 28, 2005 09:54 PM
