Speedometer Issues
Old Feb 21, 2021 | 05:02 PM
15mjditter's Avatar
Default Speedometer Issues
I have a 2003 Toyota Camry LE 2.4L 4 cyl (manual) and about a year ago my alternator went out, and then after replacing that, a few weeks later my speedometer stopped working. Went in and replaced the speed sensor and everything went back to working for the next 6 months. Then it started to randomly stop working again, so I took the speed sensor out and everything looked fine so I put it back in and again for another 6 months it worked perfectly fine. Now the speedometer randomly stops working for a few days and then goes back to working. Any ideas?
Old Feb 21, 2021 | 06:37 PM
Any relation to the weather and the speedo issues?
Have you checked the wiring connectors, ground points, circuit board for bad solder joints. The board capacitors can go bad.
Old Feb 21, 2021 | 08:02 PM
15mjditter's Avatar
No we haven’t looked into any of the circuitry stuff yet so that’s an idea, weren’t completely sure where to start. The weather varies when it goes out, at first it was summer, then early spring, and now winter.
Old Feb 22, 2021 | 03:45 AM
LaizaM's Avatar
The most common causes of a speedometer that stopped working include are a faulty speed sensor, a broken gear on the speedometer, damaged wiring, or a faulty engine control unit.
DID YOU KNOW: Sometimes you might have an issue where the speedometer is working, but odometer is not
Old Feb 23, 2021 | 02:04 PM
famlii54's Avatar
Old Mar 4, 2021 | 06:17 PM
CamryPro's Avatar
the only thing i can say is my speedometer just totally flat out broke - i had to get a new one (https://www.toyotapartsprime.com/ , got a good deal and fast shipping. i just had to enter my vin). after that my problems were solved entirely. but for you OP it seems intermittent. since the electrical components were not checked for, that would be the next thing i would suggest to be done. closer inspections should yield an answer hopefully.
Old Apr 14, 2021 | 10:15 PM
Raymond1875's Avatar
I have a 97 mine will say I’m going 100 mph but really going about 75 80 anyone have a issue like that before?
timbotison
Oct 16, 2015 07:04 AM
camryhelp
Jul 28, 2011 07:42 PM
beadingmom17
Mar 18, 2009 10:30 AM
colbetzor44
Apr 11, 2008 03:34 PM
spurlock
Jul 10, 2007 09:47 PM
