1988 camry no spark/fuel
Old Feb 27, 2011 | 01:59 AM
jrb1027's Avatar
Default 1988 camry no spark/fuel
hi i have a 1988 camry 2litre 5speed with 210xxx miles that i got from a friend for 100dollers. He said he thot it needed a fuel pump so i planned to change it but found it was good, just was not getting power from the car. So i looked for bad fuses relays even bridged the b+ to fp on the diagnostic box but still did not get power to it. So i just wired it right to the battery and put a switch on it. I got it working and have great fuel pressure now, but when i went to start the engine it just cranked and i got no fire, so i checked the spark and there was none. I have not done any ign check list yet as i have not had time. I noticed that the flap that opens and closes on the air intake hose (maf i am guessing) does not work either of course i had that off of the intake when i was trying to start the car however it was still plugged in to its harness. Does it have to stay on the engine to open? So i am guessing i have some king of major electrical problem hopefully a fuse or a relay. Also the fuel pump would never kick on even when i had the engine cranking and the other electrics on the car such as automatic seat belts lights and dash work i was not sure if they were connected with the failing parts power sources so i fugured i would add that. Thx for your help
Bam Bam 65
Oct 20, 2013 05:54 PM
manty1
Apr 10, 2013 04:54 AM
Nromo
May 7, 2011 01:18 PM
jrb1027
Mar 3, 2011 09:15 PM
jrb1027
Mar 3, 2011 08:52 PM
