1995 v6 a/c idle control
Old Jan 30, 2009 | 10:04 PM
  #11
happyg's Avatar
engine compartment, firewall area.
yes i know its OBDII, was looking for specific brands/model recomendations.
Old Feb 1, 2009 | 05:06 PM
  #12
Try a history search on Toyotanation as members have posted their recommendations.
Old Feb 12, 2009 | 03:54 PM
  #13
happyg's Avatar
found a solus on craigslist for cheap just need to get some updates now.
anyway, i believe the dealer tried to adjust the idle by adjusting the butterfly stop, and now the tps is off. last i looked at the car it seemed that the clic was comng from the tps? is that even possible?, lol.
anyway, any easy to follow throttle stop/tps adjustment instuctions?
thanks again.
Old Feb 12, 2009 | 05:20 PM
  #14
The TPS does have an internal switch and a potentiometer.
See link for TPS adjustment.
http://www.autozone.com/addVehicleId...00c152801ccc16
Old Feb 13, 2009 | 11:30 PM
  #15
happyg's Avatar
alrighty then,
checked/adjusted tps, iac, a/c idle up valve. everything correct.
still misses intermitantly at idle and initial take off.
got a video, if you dont mind wasting 3 minutes of your life.
but pretty hard to hear the miss, might need to try a different angle
here we go!
http://media.putfile.com/camry-idle
thanks
Old Feb 14, 2009 | 11:41 AM
  #16
Will need to find a computer with a sound card that works.
What you stating is the engine misses under load.
Have you checked the plugs, ign wires, etc.
Not sure the IAC or TPS would cause a miss, but high/low idle, hesitation, etc.
Old Feb 14, 2009 | 12:44 PM
  #17
happyg's Avatar
at idle/just off idle, never under load.
new plugs.
wires to coils look fine.
Old Feb 14, 2009 | 04:49 PM
  #18
Can only guess.
A miss when NOT under load and only at idle sounds like a fuel problem.
You cleaned the IAC valve. The IAC valve is not monitored by the ECU for this year, thus a trouble code would never be set.
Any issues with the EGR valve. A slightly leaky valve can cause idle issues.
Old Feb 15, 2009 | 12:33 AM
  #19
happyg's Avatar
guess?, yup me too!, lol
i know its going to be somthing so simple!
thats whats so irritating.
thanks
Old Feb 16, 2009 | 01:54 PM
  #20
Can not tell much form the audio.
Use a section of rubber tubing as a stethoscope to pin point the noise area.
jcott948
Oct 5, 2016 10:40 AM
strausbo
Dec 16, 2011 08:35 PM
eriknspice
Feb 4, 2010 06:10 PM
1995YotaCamry
Oct 17, 2009 05:38 PM
ldballoon4
Jan 21, 2009 06:35 PM
