2.2 runs somewhat irregularly while driving
Old Mar 2, 2019 | 02:39 PM
  #11
Rob Wapperom's Avatar
Joey, I placed another wire on coil nr 3 but it makes no difference.
there are no leaks or other strange things so far as I can see
12v wiring looks alright, but are there some points on this wiring that I can check wiht a multimeter (ohms/volts)?
Regards; Rob
Old Mar 3, 2019 | 10:43 AM
  #12
Spark plug wires should have a resistance of 25K ohms of less.
Coils resistance between primary (ign wire plugs)
Cold 9.7-16.7 kohm. Hot 12.4– 19.6 kohm.
Black/Red wire should be battery voltage ign on.
Brown is ground.
The other wires go to the computer.
Camshaft position sensor Cold 835–1400 ohm. Hot 1060–1645 ohm
Crankshaft Cold 985–1600 ohm Hot 1265–1890 ohm
Is the No 3 plug electrode darker/lighter then the other plugs?
wdc123
Mar 26, 2016 02:30 PM
1989_Camry
Jul 19, 2015 02:34 PM
KEVAUG
Jan 8, 2014 04:26 PM
Bjorn
Dec 23, 2013 01:13 AM
