2001 toyota camry idle dropped close to 0 RPM randomly, now it will not start
Old Jul 3, 2017 | 08:05 PM
Dill's Avatar
Default 2001 toyota camry idle dropped close to 0 RPM randomly, now it will not start
After stopping at a traffic light, and the car running perfectly fine until that point... i proceeded to accelerate, but my camry idle slowly dropped close to 0 RPM and i had to roll off the side of the road. Up to this point, my car refuses to fire up.
I have changed: fuel filter, air filter, fuel pump, spark plugs and air intake hose set-up. some of which needed some TLC, all problems aside. What is my next move?
Old Jul 4, 2017 | 12:26 AM
Engine type?
Old Jul 4, 2017 | 01:16 PM
Dill's Avatar
Default Toyomoho
Engine type?
2.2 liter
Old Jul 5, 2017 | 07:12 PM
Check for ign spark.
Any chance the timing belt broke?
Old Jul 5, 2017 | 07:22 PM
Dill's Avatar
I just changed timing belt and the fan belt a few months ago. They seemed intact. I guess i didn't quite fully check!
Old Jul 5, 2017 | 07:29 PM
Check for spark?
If OK. Crank engine with plugs out and determine if fuel is being injected into the engine.
The fuel pump will only run when cranking or engine running.
Old Jul 5, 2017 | 07:57 PM
Dill's Avatar
Check for spark?
ok will do, thanks for the input. I cannot get to it until tomorrow or Friday. Ill keep you posted on how things go. Cheers
Old Sep 8, 2017 | 05:29 AM
tkliggs's Avatar
Hi, which 2001 Camry has a fan belt?
Old Sep 8, 2017 | 05:46 PM
Electric fan.
Samardas
May 18, 2016 02:55 PM
blackjak22
May 4, 2011 10:26 AM
kjvb7202
Dec 31, 2008 12:37 AM
Camry01
Oct 13, 2006 02:38 AM
