2002 speedometer stuck
Old Dec 7, 2008 | 10:08 PM
kskin1's Avatar
Default 2002 speedometer stuck
Hi, My speedometer is stuck all the way to the right. It also had a rough time starting.
I have a 2002 v6 camry se. I checked the battery and it was fine. I saw a similar post in 2007 but there was no solution.
Please let me know if you can think of a solution.
Thanks,
Karl
kskins1@gmail.com
Old Dec 8, 2008 | 09:13 AM
Default RE: 2002 speedometer stuck
Can you be more specific on what rough starting means?
Did you happen to discconnect the battery before the speedo problem?
Old Dec 8, 2008 | 02:03 PM
Sean S's Avatar
I had the same problem this morning! I have a 2002, 4 cyl., SE. I replaced the battery last night and ten minutes into the drive this morning, the engine starts to idle rough and stalls. It restarted, but stalled at idle, could keep it running by revving in neutral. Speedometer also pegged itself at 140 at the same time. After a few minutes, I smacked the dash a few times and the speedo returned to normal. Rough idling problem disappearedjust as I drove into the lotof my mechanic. They cleaned the throttle body (dirty) and said they can't get it to idle roughly.
This was the first time in two years of ownership that the battery was disconnected.
Old Jan 2, 2009 | 09:01 AM
LeeM's Avatar
I had similar issue
After the battery was disconnected... the tachometer arrow was pointing to 7-8 and speedometer arrow was pointing to 75-80mph
https://www.camryforums.com/m_18482/..._/tm.htm#18482
https://www.camryforums.com/m_18217/mpage_1/key_/tm.htm#18478
Old Apr 3, 2018 | 04:58 PM
tyno's Avatar
Default Toyota camry 2002 4l,,speedometer stuck all the way to the right
Just today as I finished cleaning the throttle body , I disconected the battery and reconected it in order to reset the check engine light, the speedometer neddle is stuck to 140+ ,, does not go back by it self. Any suggestions???
Old Apr 4, 2018 | 11:33 AM
This is common on cars when the battery is reconnected.
Try driving fwd and hitting the dash area to unstick the needle.
Or disconnect the battery for 15 minutes.
pborchardt
Apr 30, 2014 11:35 PM
pborchardt
Apr 26, 2014 10:58 PM
JohnGreen
May 12, 2008 10:46 PM
colbetzor44
Apr 11, 2008 03:34 PM
spurlock
Jul 10, 2007 09:47 PM
